I'm having a set of external floor to ceiling glass sliding doors fitted, and the door fitters have advised that I need to fill the current (55mm) cavity void to level with the top of the floor brick work as the door frame needs to sit on a solid base. The frame will sit on the outside course of bricks but is not wide enough to also sit on the inner course, hence having to fill the void. The fitters have advised me to just back fill the void with concrete. Is this correct?
If so should I line the void with a dpm then concrete? Also what mix of concrete would you advise?
Thanks in advance.
Thanks in advance.
