    Dismiss Notice
filling wall chase for heating system?
Discussion in 'Plumbing and Central Heating' started by A.J.T, 3 Jan 2017.
  1. A.J.T
    A.J.T
    3 Jan 2017
    3
    Thanks Received:
    Country:
    Hello
    I have chased out my walls for the heating system , they are coming up from the floor and are In the wall for about 7 inches.
    I have used hep2o and was planning on insulating them before plastering with either a tape or conduit to allow to expansion.
    My question is how to fill the voids around the pipe ? I was thinking about using expanding foam then covering it with some plasterboard or can you plaster straight to the foam,?
  2. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Plaster products will be fine, providing you allow for expansion or plaster may crack.
  3. Sponsored Links
  4. rob_j20
    rob_j20
    23 Feb 2016
    121
    Thanks Received:
    8
    Country:
    Run the pipes in conduit and secure to the brickwork, then plaster over the top. Its how i do my network cables allows you to remove if you ever need to, should work fine for pipes and allow expansion/movement.
  5. A.J.T
    A.J.T
    3 Jan 2017
    3
    Thanks Received:
    Country:
    The only issue is the holes are quite big so need filling somehow
  6. Sponsored Links
  7. dilalio
    dilalio
    20 Mar 2009
    7,447
    Thanks Received:
    1,160
    Potters Bar
    Country:
    Does this mean that you have a pushfit elbow buried in the wall??
    Or have you used a compression elbow? Either way, soldered copper would be the way to go!
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
