Best way to cover chased pipes
Discussion in 'Plumbing and Central Heating' started by Nedley, 14 Nov 2018.
  1. Nedley
    Nedley
    21 Oct 2016
    18
    Thanks Received:
    Country:
    Hi all, I am about to chase some rad pipes into my wall, but not sure of the best way to cover them before the plaster comes and skims...
    Firstly I know about the regs for the depth of the chase and I understand I need to cover the pipes and allow for expansion.
    My plasterer is a friend and not an expert so doesn't like doing the binding layers and filling in large holes, so ideally I need to find a solution which will allow him just to skim over everything.
    What I was thinking of doing was simply putting plasterboard over the channel I chased and attaching it with the expanding foam glue stuff. Only problem is I haven't seen anyone suggest that on the internet so I'm thinking it's a stupid suggestion!!
    Any advise would be much appreciated
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    I insert plastic conduit over the pipe, I assume they are going to be copper, but if you are using plasterboard just use amalgamating tape as a protection against corrosion where in contact with limestone walls and leave some expansion space.
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
