- Joined
- 14 Feb 2013
- Messages
- 7
- Reaction score
- 0
- Country
To use my Gas Central Heating I have to top up the system to 2 bar. (any less and the pipes bang and the pressure needle jumps around). The boiler fires up and the radiators heat up as they should. The pressure gauge on the boiler touches the red when the system is fully warmed up and then gradually drops until it hits the red at the other end of the dial when the pipes and boiler bang and the error message is shown. This process takes about 12 hrs.
I am aware that there must be a leak on the system but there are no signs on walls or ceilings as to where it may be.
I was wondering if I was to call out an engineer would he have any way of finding the leak using metres or something or would he want to start tearing up floorboards etc., which sounds horrific.
My thoughts are just to top up the system when I want to use it and continue in this way unless any signs of the location of the leak occur.
Any thoughts?
Many thanks
Any thoughts?
Many thanks
