Does anyone know of a place that sells a square cover for the expansion gap around a 22mm pipe?
I am planning to lay oak laminate flooring but need to find a cover for an expansion gap around a 22mm (gas) pipe that is almost touching the skirting board.
I don't want to remove the skirting (and it would be really difficult around that gas pipe as the pipe comes so close to the skirting board from the floor and then goes through the wall just above the skirting board) and was planning to use scotia.
To make it look tidy around the pipe I think it would be best to use a square cover, that I trim down to accomodate the skirting, and then run scotia on both sides.
However, I can't find any square covers for 22mm pipes (for 15mm pipes I found this http://www.creative-wood-floors.co....-pipe-covers-rad-rings-collars-for-15mm-pipe/ but I am after somehting similiar in the right size)
