finishing rough sawn timber
18 Oct 2004
Gloucestershire
Hi
We have recently had a loft conversion done. I have almost finished all the decorating, however i'm unsure what to do about the purlins, which are exposed in the new room. They are rough sawn unfinished timber.
I was wondering whether I could dark woodstain these, or prime, and then apply the same emulsion as I applied to the walls?
You do whatever you like really...both options will work...depends on what looks better in the room
If you go for the stain then I would suggest giving them a coat of oil based flat varnish after...its a more natural lool
Or, as you said, paint...you can get away with using a thin coat of emulsion first then finishing with a full coat
Or...prime with acrylic primer then emulsion.
I haven't a clue on type of paint, just make sure the purlin can breathe as it's important part of the roof structure.
Zampa may know, treated it with oil???
Thanks for the info
Distemper is porous, but very expensive. My dad uses it on the walls in his very old house as the walls are constructed using lime mortar, and must be allowed to breath.
I don't know whether matt emulsion might be ok for this.
Hmm...ok then what about using contract emulsion instead?
Its vapour permiable unlike ordinary vinyl matt and its cheaper.
