Finishing trowel or float?
2 Mar 2009
Suffolk
Just been looking online at trowels, when I came across Magnesium Float, sorry to sound thick, and am only a beginner, but at the moment I just use a finishing trowel. When or at what stage would a Float be used?
Just found an plder post from Roy C, apparently a float is used in rendering!
A plasters float would be used to even a base/rendered coat surface out, a devil float would be used to key it.
A trowel is used to lay on your coats of plaster.
Sometimes the terminology between float and trowel are confused a when using plastering tools.
Float
Trowel
Plastic float
Float
a top quality plastering trowel..
Trowel
a good quality brick laying trowel
Plastic float
a rendering float ( not one I myself would buy) , but a float ,non the less...
how about this one roy? click on the "click here" tab to watch a vid of it in use http://www.brickytool.com/catalog/product_info.php/cPath/28/products_id/983[/QUOTE]
Sorry Steve but I am afraid I am a bit "old school" when it comes to floating, I tend to use Stadium floats and when I get them I sand the corners off and sand the "pattern " off the float, if no sander then I will rub it on a concrete block till surface is nice to use. I tend to float up as soon as poss and sometimes give it a second float, If you look at that video the muck was too dry when he was floating it , and any way I will always sponge up after floating.... As you probably know you only need light pressure when floating and I tend to hold the float vertical with light pressure and always float with downward stokes. Interesting to see what the lads think... :wink:
so your technique is rub up twice with the float and then leave it off a sponge finish?
It depends on the size of the job Steve, sometimes theres not always time to give it a second float but if I can I do...Also a lot of my jobs involve other things aswell, like the last one I have just finished was on a 4 storey house and we had to knock the chimney off and rebuild most of it, replace lintols on all the bays on each floor, take out a fire escape and fibre glass the gutter and over the bay window, and cut out cracks and mesh and bring them back in. So I get a lot of variation around my rendering and plastering.. :wink: I have tried to load pictures on my album of that last job but cant get the pics to load, I will have to get the missus to show us again :oops: Must be an age thing.....
alright roy cheers let us know when you have managed to upload the pics
