Plus fitting costThe extra money for a hinge?
It might depend on the number used in the doorset when it was certified, in which case that will be what needs to be used on installation.
Can you explain more numbers used?
Downstairs have 3 hinges fitted as regular use. 2 hinges fitted to bedroom.
It is a domestic property. Do you have anything to support this pleaseYou should not need more that two hinges for a domestic property
But none of that will cut the mustard with Mr BC though will it. The OP needs to study the BS otherwise Mr BC will just insist on what he's seen done on every job before him and never been challenged on probably. Rightly or wrongly it will be for the OP to prove only two are required if indeed only two are adequate.Yes, the doors won't be heavy enough, the linings won't be thick enough and the usage won't be regular enough to require a third hinge.
Non of this relates to the door as a fire door though, just to the door as a door.
The bathroom door is more likely to need a middle hinge for humidity reasons, and the front/ready door for security.
