Fire Doors
22 Dec 2011
Sussex
We are moving to a new house - well a conversion but everything except the walls is new. Anyway, the doors were all fitted but now have to be replaced with fire doors. These look the same apparently (oak veneered) but are thicker overall. The reason is that in one of the bedrooms it will not be possible to use the windows as a fire escape.
I have two questions:
  • If the doors need to be fire doors does that automatically also mean that they need door closers?
  • What is the difference in internal construction between an oak veneered non-fire-rated door and a fire-rated one?
1. No
2. Thicker, denser construction, usually a slab of chipboard. Has been tested, certified and marked. You can only trim a small amount off, and nothing from the top edge, where the markings are.
Due to increased thickness and weight you will need certified hinges. You may also need new doorframe (liners).
I wonder how (or "if") the conversion received Building Regulations approval with incorrect doors.
Regarding fire door closers, you need to ask whoever is telling you you need fire doors what specification they are talking about.
Normally, no professional will say "fire doors" but should refer to a "fire doorset" - which means the door, the frame/ lining, and the furniture.
So you don't just plonk any old fire door on, and that's it.
Ah, thanks both.
Just to be clear then, the builders are doing all this, they just told me for my information as it were. So I'm sure that all the right language was used between the inspector and them. I'm just being curious with question 2.
The other difference, of course, is cost.
Fire doors are much more substantial, and give an impression of quality which cheap hollow doors do not.
They muffle noise.
Jumping in on this older post because I’m dealing with a similar situation now regarding fire doors in a conversion. Did anyone here later find out if closers are actually required by building control? I’m curious how strictly that’s enforced.
Not required for domestic internal installation.
Reason being that people would inevitably use door stoppers and in the panic of a fire leave the doors open.
An unobstructed door can simply be pulled/pushed shut in a second whilst escaping.
Rolfis, I do not live in your country and have no idea what regulations you are obliged to follow. The same goes for the vast majority of users on here. Ask your local regulator.
Your builders should have provided certification for the fire doorset. For escape without a window, I’d also check if you need a tested fire proof windows in that room, as I personally use them for extra safety in similar layouts. They help slow fire spread while keeping light, which feels more secure than relying on doors alone.
