Im thinking about installing a fire pit into decking, Im posting this in the building forum because im guessing you guys will have a better idea about materials to contain heat than the garden forums. If your not sure what a firepit is, its basically a brick or stone outdoor fire, they dont seem so common in the uk but seem to be popular in the states
they can look like this:
my idea is to build a smallish one at the back of the house that comes up through the decking, at the location of the pit, the decking will be at most 25cm from the floor, maybe a little more when ive taken up the old block paving.
I will have the firepit come up one or two bricks from the level of the deck, but the fire will be much lower down inside. I wondered what kind of materials id be looking at building the pit with that would be able to protect the decking around the pit from heat.
also does anyone know of any laws around fires and proximities to the house structure especially in this configuration where they are permanent and not a chiminea etc
The bottom of the pit is a layer of sand on top of gravel or hardcore for drainage so shouldn't fill with water if done correctly as the base of the fire should be about level with the original garden floor.
I will then build a cover from the same decking so i can cover it when not in use.
thanks
thanks
