I plan to convert part of single storey integral garage, single block into a small living room.
The external walls I am going to insulate with insulation and stud.
Is it possible to use a stud wall instead of block between the garage and new rooms? I could use fire retardant plasterboard etc? Would this be enough with fire door?
If so the loft space is an issue as rafters run from garage door into new room. I assume this area will need separated also? Any advice on this?
Any advice would be appreciated. I plan to do most of the work myself but would prefer to diy stud if possible.
