If your boiler has overheat protection then a simpler and less expensive way is to pipe it like this:- View media item 29821Simple bit of pipework. The only somewhat tricky bit (for a diyer) is cutting hole in expansion tank.
Ideally with about 1ft between the expansion and cold feed.
Ok ... Well mine looks instantly wrong straight away then as from my boiler there is a pipe with the pump attached about a foot of pipe work away with an arrow pointing away from my boiler. Where this goes i dont know as i cant trace the pipe work to easy but i guess this is a problem straight away?
Pump can pump harder and therefore drive the water to more radiators and bigger distances.
With a vented system the pump is limited by the amount of head pressure
the header tank can supply
With a vented system the pump is limited by the amount of head pressure the header tank can supply.
For long distances where or pumping up close to the top of the house near
the header tank it becomes easier for the pump to pump water into the header tank than the radiator where you want it.
we could do with a bit more info , make /model of boiler and if system is fully pumped or gravity hot water/ pumped heating as its all guess work at moment . and my guess is it has a slight leak on pump valve which is sucking air in when in use
Sealed system doesn't have this problem. Full force of the pump is supplied to the water pushing into the radiators.
