Hi
Fitting a integrated oven, I have solid 40mm wood worktops
Do i need any heat shields around or above the cooker, i have a induction hob fitted above the over as well
I also have a problem with the oven not fitting, it is too high about 40mm when fitted into the over carcase
The only way i can see is to remove the carcase and drop it down, and use the metal support brackets supplied but this will mean it will be lower than the bottom of the carcase and the plinth will have to be steeped around it any suggestions
Thank you for your help
