ok folks i want to put electric outside i have power on a conservatory wall so was thinkin i could just take the box off an drill outside thru the back of it an connect an waterproof box outside or do i need to do it differently
Whether on not you can, or cannot do this is really down to the circuit you intend to 'spur' off of.
Is the circuit RCD protected ?
Is the socket in your conservatory on a ring main, a 'spur' or part of a radial circuit ?
What 'load' are you expecting to need feeding ? ( just mowers etc ? Or maybe a welding set ! )
Let us know and I'm sure someone here will be able to advise you further.
If the 'power' is a socket or double socket on a ring main (two cables actually connected to the socket, and if the ring main is RCD protected, then you should be OK. If the socket is a spur from a ring main then you can't do this, and also not if there's no RCD, although in that case you should be ok with a weatherproof socket with built-in RCD protection.
You ought to use plastic conduit to take the cable through the cavity, and don't forget to drill slightly downhill from the inside. Take the conduit up into the bottom of the weatherproof socket, using proper conduit connectors. Follow all instructions of the outside socket manufacturer.
