I need to fit a new bath, but when you buy them they come with just the bath and no support frame or adjustment ( its overseas) How is the best way to make a frame to support same? Also the outlet ( which is supplied ) needs 5 inch minimum clearance off the floor I am proposing to sit the bath on blocks of 125mm timber x 600cm accross the width of the bath at least 5 times to :
Take the weight of the person and water in the bath
To get clearance for the trap
Is this the right way to go or should I consider any other methods? The frame I was just going to make up of 50x50 so that it sits snugly under the lip of the bath so that the bath is supported but the weight is taken by the blocks mentioned above under neath . Will this be OK ?
regards
regards
