I have just purchased a Crosswater Galaxy 3 Hole Basin Set GX130WNC
as per:
http://www.crosswater.co.uk/productsgalaxy.php
The kit has arrived this morning and it basically consists of:
2 x hot and cold diverter taps, each with two brass female G1/2" screw fittings on each end
1 x basin filler with a brass female G1/2" screw fitting on the back
I am going to feed this with two 15mm copper pipes (hot and cold) and I wondered (before I make myself look like the plumbing idoit that I am!) what do I need to get this all connected together??
The tap-filler-tap are separated by 100mm if that helps.
Many thanks in advance for anyones help!
[/url]
as per:
[/url]
