fitting a gate if your fence has concrete slotted posts
20 Feb 2007
Leicestershire
Hi can anyone help i have a 6 x 6 high fence which has been put up using slotted concrete posts and 1 ft high gravel boards , i want to fit a 6 x 3 gate at the end but do you use a timber post to hang the gate to or can it be done using the concrete post . thanks hope someone can help
you can fix a timber batten to the post usually a 100x50mm section timber is about right. 7mm drill with brown plugs into the centre of the slot.
