    Dismiss Notice
Fitting a Lintel
Discussion in 'Building' started by bluenun20, 16 Apr 2015.
  1. bluenun20
    bluenun20
    3 Feb 2009
    196
    Thanks Received:
    Buckinghamshire
    Country:
    If I was going to install a 930mm wide UPVC door to my garage, what width Lintel would I need to fit?
  2. tony1851
    tony1851
    23 Feb 2012
    10,307
    Thanks Received:
    1,558
    Manchester
    Country:
    The width of your lintel will normally be the same as, or a ittle less than, the thickness of your wall.
    Or did you really mean the length of the lintel? If so, 100mm added either side should do.
  3. Sponsored Links
  4. bluenun20
    bluenun20
    3 Feb 2009
    196
    Thanks Received:
    Buckinghamshire
    Country:
    Thanks for the reply.
    Yes I meant the length.
    wickes sell steel reinforced concrete Lintels in 1200mm or 1500mm lengths so 1200mm will be long enough.
  5. tony1851
    tony1851
    23 Feb 2012
    10,307
    Thanks Received:
    1,558
    Manchester
    Country:
    Yes, no prob.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
