Dear All
New to the site and need some help. I replaced a thermostat however with little electrical knowledge I replaced with a 2 x wire unit not a 3 x unit unit that was required. Consequently I blew the fuses!
I replaced fuses and then replaced the Thermostat with an identical unit a Drayton RTS1 (3 x wire system). Connected wires as per original unit i.e Blue into Neutral , Red into Live and Yellow into No 3. I however now have a new problem....
When the Central Heating is on the OFF position on the wall and I turn the thermostat until it 'clicks' the boiler and the pump come on????
Any suggestion as to what I can do would be appreciated
