Hi
I would like to fit a shower pump for my bathroom shower which is gravity fed. I live in a bungalow & the supply to the shower comes down from the loft. The hot pipe comes from the hot tank in the airing cupboard, goes up through loft, along then back down to shower. The cold pipe comes straight from tank in loft. They both run parallel with each other in the loft before going down the inside of the wall to the bathroom. Could I just cut into these two pipes & put the pump in the loft? Also, where could I tap into an electrical supply from?
