fitting a whirlpool bath
2 Nov 2007
Gloucestershire
have just installed a new whirlpool bath. I have to connect the electrics. I am competent at DIY but not a qualified electrician. Does anyone have tips if suggestions? I assume an isilator box needs to be installed
thanks
R
Firstly please be aware that this work is notifiable to your local area building control under part p of the building regs.
Which circuit are you looking to connect into? Are these included in the supplementary bonding? What does the manufacturers instructions say, does it require RCD protection? You will need some sort of isolation, also more than likely it to be fused down from the circuit where it is fed from. The isolator etc will need to be installed in zone 3 or beyond.
