Fitting a wireless thermostat to an old central heating time
5 Jan 2011
Yorkshire
Hi guys, my current timer is a randhall 102 and controls both my heating and water, it works fine except its in a difficult place to get to, I dont have any current thermostat installed, but i was advised to buy a wireless thermostat as i'm wanting to control my heating without having to go to where the current timer is, so I bought a horstman hrfs1 from b&q (I know its probably not a great one but b&q is close).
The guy from b&q said I would be able to replace my timer with this, but I dont think I could as my current timer also controls my hot water, so what I think I need to do is wire the thermostat to my current timer, but sinceIi dont have a thermostat installed i dont really have a clue how to do this, could anybody help, please.
Also the reciever needs a live and neutral could i bridge a wire from my exisiting live and neutral of the timer?
You are right that you will still need the timer to control the DHW. Yes you can bridge the live and neutral from the timer to the new receiver. The contacts of the thermostat receiver need to be connected in series with the CH output of the timer. So connect the CH On output of the timer to the COM terminal of the receiver and connect the wire that you have removed from the CH On output of the timer to the NO output of the receiver.
You will probably need to use some choc bloc terminals to make the interconnections.
Thankyou, that seems very simple then, only thing im worried about is that my CHON is bridged to the pump as I dont currently have a thermostat installed, do I just take this out and wire it to the no output of the reciever yeh.
.. my CHON is bridged to the pump as I dont currently have a thermostat installed, do I just take this out and wire it to the no output of the reciever yeh.
It sounds like you have a gravity fed DHW system and pumped CH. So yes the pump will be switched from the NO output of the receiver.
