We are knocking through a support wall between a galley kitchen and dining room and I'm looking for some advice on how I should approach this regarding building regs.
Getting the actual RSJ installed wont be a problem, I just need to understand what size/type of RSJ I should fit and how much of an overlap into the side walls I am going to need.
The support wall is single brick, and goes all the way up between two bedrooms, towards the back of the house. The load bearing for the roof travels down support walls further in the house as the opening i am looking to make is below the eaves. Obviously I still need to support the bedroom dividing wall above it though.
The opening I am making will span 6 feet 2 inches and there will be enough brickwork either side to allow up to 8 inches of overlap for the RSJ.
Is the math fairly straight forward for calculating the RSJ installation for this job or should I pay a structural engineer to tell me what is required?
I don't mind overkill in terms of the size of RSJ required if it will save me cost on the structural engineer and pass building regs.
Any help/advice would be appreciated.
