Fitting floorboards to joists
23 Apr 2024
Hi all, having new carpets so I’m wanting to fix the floorboards which previous trades had lifted and not secured down. Just checking how careful I have to be with putting a screw through the floorboard and into the joist. Screws are 5mmx40mm, about 20mm of which will go into the joist.
I can’t get all of the screws into the centre of the joist, so will be close to the side. Any issues with this?
Identify where the pipes are before you screw..
I done that once and still hit a pipe!.
There were 3 radiators pipes when I thought there should only be 2 and stopped looking when I found the 2.
Ha thanks! Yes done that, identified all services. Just wanted to be sure of not damaging joist integrity
Drill a small pilot hole and countersink floorboard for screw head..
Just nip screws up so they don't crush in...
Will be a tidy job
