Just got a few questions about fitting an immersion heater to my hot water tank (as currently its just heated via my boiler).
I have a 900 x 600 96 ltr vented indirect cylinder and would like to know the following...
1) what size immersion heater should be fitted? (the physical size and power)
2) how should the immersion be wired? What size cable? Via a fused switch? What size mcb?
3) under regulations will this require it's own circuit from the consumer unit?
I realised after being away at the weekend and having the hot water and heating switched off that if my boiler fails I have no way to heat water and so therefore would like to install an immersion as backup.
Any advice would be appreciated.
