The problem i've got is that I need to replace an old lead bathroom suite which is in a flat. So, I can't replace the entire lead pipes from the street and can only have to connect up to where they enter the flat. (which is in a viod in the wall) Is possible to do just that? At what part of the old lead pipe do I connect on to as they vary in thicknessess all along the run...some it seems they go down to about 15mm and others beyond 22m. Do you just cut the lead where its thick enough to use the new coupling etc?
Cheers,
J
Cheers,
J
