Hi all
We have knocked together two rooms on the ground floor to form a through lounge. The old floor boards taken up and the floor joists exposed. We will put PIR insulation between the joists and then screw 18mm plywood on top of the joists. The floorboards will then be held in place with cut floor brad nails (pre-drill 3mm hole in the floor boards to stop splitting) for a rustic look.
As this was two separate rooms the floor joists do not align as you pass from one part of the room to the other and we would ideally like the nails to run in straight lines across the floorboards in both parts of the room. Therefore do the nails need a joist to fix into or can they be fixed just into the plywood. If a joist is needed then we would move the joists over in one part of the room.
Thanks for any advice you can give me.
