Fitting small window beading?
14 Sep 2010
Rochdale
The long ones are easy, the short ones are 7w@7$.
Is there a technique? All I can think it to attack the back of it with a grinder to give it more flex.
If the ends are mitred which I suspect they are then put the short ones in first, the longer ones have more flex
I've just got a really small window left to do so all 4 are short. I can easily do top/bottom or left/right but not all 4 :(
Can you post a picture of the cross section of the bead, is it single or double legged, in the absence of pics I would go with your suggestion and put some relief cuts in the back to help with flex, this is something the factory sometimes does for you
The windows are 70mm Rehau and the beading is quarter round with a small flat bit on each end. I think the is just 1 strip that knocks into the frame.
Nearest I can see on Google would be this:
Ah OK probably S706 then, one of the easiest beads on the market to get in what's up with you man! Unfortunately it is just a case of bending the bead in the middle, start by getting one mitre in as much as you can, the trick is in bending the middle while trying the get the second mitre in all while stopping the first one popping out, softening the bead with hot water could help, a pro would do it in seconds, bish bash bosh and away
I had a similar experience glazing a small window, about 200mm square with mired beads. I could get 2 in dead easy, 3 was not too hard, but getting the 4th in was !@%#! Some window suppliers supply the beads scribed which I like much better!
I managed to get it in in the end with brute force but I was really afraid of snapping the thing.
cut about 5 lines in the middle all the way up the little leg at the bottom that way you can bend the bead easier
