Fitting Tri Iso 10
3 Jul 2006
Is there any way to avoid having 25mm battens between the plasterboards and the tri-iso, e.g. foil backed boards?
Thanks j-, I have slates, tyvec then 150mm air gap. Do I need the EXTRA 25mm between the plasterboard too?
The reason for the battens is so that the tri iso does not get squashed flat, they should be fixed ar right angles to the rafters otherwise you will get cold bridging and pattern staining after time.
Jason
