Want to fit a new door & frame (pre-hung)
The frame is wood with cill etc.
The are weather seals routed into the frame and I didn't fancy drilling and screwing through the frame... it's factory painted too.
Is an acceptable method to screw sturdy plate/flat brackets to the sides of the frame, slide into the opening, then fix the brackets into the inner brick skin with concrete screws?
I'm thinking of cutting these down.
https://www.toolstation.com/shop/Co...Metalwork/sd2797/Heavy+Duty+Strap+Flat/p50096
Just wondered if those in the know can see any issues, or a better way.
