I have a large (32inch) and heavy LCD screen that I am trying to fix onto wall. I have a bracket that says it will withstand well over the weight and screws and rawl plugs but am still a little worried it will take weight. The rawl plugs I was sent are a little shorter than the large screws supplied which means that they open when screwed in which I am a little worried about. Mayb I should get larger ones? Also two of the rawl plugs I have are a little loose when I put in holes - will it be ok to put some matchsticks in with them so they fit snug.
Hope someone out there can help,
Dan
Dan
