I have recently discontinued using an oil burning stove (for obvious reasons!) which had supplemented our oil fired central heating.
I put a 12mm brass compression stop end on the tee feeding the stove. However, at the nut end it is weeping oil although I did wrap some pft tape around the thread of the end part.
Should I undo the joint and put some boss on the olive, or wrap some tape behind the olive at the nut end, or wrap tape around the front part of the pipe, or what? Do I need to use any products specially designed for heating oil?
