I would open it up about just over 2" (inch either side of crack) and take off the finish coat down to about 3mm then put some scrim tape in it, Then unibond over it and let it go tacky then fill it with easi-fil level it off ,leaving it a bit proud and sand when dry. Or put a coat of multi on it then another one and skim it flush... I always try to taper each side so I don't have a straight joint when I finish it off..
