Hi
I want to fit some Heavy 4ft x 8 1/2" x 1 1/2" shelves into alcoves on each side of my living room chimney. I want the supports to be hidden but not sure of the best way of doing it.
After noticing the pin supports for shelves in my kitchen cupboard I thought about doing something similar. Perhaps using heavy duty screws or fixings into the walls and resting the shelves on these "pins" (I would also make small recesses in the shelves to fit over the fixings to make them invisible). I am not a that good at DIY so I am not sure if it will work or the best way of making the even (uniform)recesses in the wood, perhaps a drill and small chisel).
Has anyone tried this or can suggest a better alternative? I don't want to use floating shelf brackets as this means drilling a large hole in the shelf and if its not straight I could drill through the top or bottom side of the shelf and ruin the (expensive) ok I am using. Also, I feel floating shelves may not be strong enough.
Graham
Graham
