I am removing wardrobe doors, each being 400mm x 2400mm. The plan is to fix 3mm glass sheets to the front of each. Weight is not a problem as each door has four sturdy hinges.
However, I don't really want to see any signs of a physical fixing and so would like to use an adhesive.
The doors are standard chipboard that have laminated surfaces.
Any reccomendations based on experience greatfully received on which adhesive to use.
