Hi there,
I am installing a bi fold shower glass door, standard glass door with x2 wall panels/channels that slide over the edges and are secured to the wall. I have put the 2 wall panels into the enclosure, marked and drilled holes then fitted plugs.
The problem is that when i present the door into the enclosure as its walled on either side you have to have the wall panels attached to the main door. I can get it in place no problem lined up with my holes..
Problem is i cant fit a screwdriver to screw the wall panels on with the door in place as its in the way!
Any ideas or tips, i thought of using some sort of ratchet screwdriver but don't think even this would fit in. Surely I am missing something, anyone fitted these before?
Cheers,
Roverblue
Cheers,
Roverblue
