FJS 1425W
23 Feb 2010
Could some one help let me know how to check the pressure switch is ok or not on the Zanussi FJS 1425W washing M/C, All other things are ok drain et. pump all working. But the m/c would not run stops in between and start/pause light starts flashing, why it is doing it. some time it is Ok run full cycle. Help help
you can pull the pipes of the pressure switches and the connection to the sump hose
could be full of brown crudd blocking the pressure switch
you can take off the pressure switch and blow into the connector, you should here a click and then another click as the pressure from you blowing is released
