I am doing a diy build on a garage and need to know what size of joist/truss to use for the span width.
I have a span width of 5.2m to the outside of the brick for a 14ft door and the garage is 7m long door to the back.
I was told to put the joists every 600mm along the lenght of the garage.
Do I use 45x220mm as this will fit the height of a block in the wall when building or will I get away with a smaller size 45x150mm?
Cost aint hugh issue if the weight of the roof will be! But the cheaper I can get away with the better.
Cheers in advance.
Cheers in advance.
