Flexi to Female Compression Elbow
U
User
Howdi :D
Is it possible to connect a 15mm flexi to a Wallplate Elbow 15mm x ½"?
If so would you use ptfe or a fibre washer?
Also is it possible to connect a flexi direct to a compression isolation valve?
If so would you use ptfe or a fibre washer? :confused:
Howdi :D
The flexi will fit to 1/2" no problem and to a iso valve no problem. What to watch on iso valves is they can be sharp where the iso meets the washer on the flexi - so cannot be tightened too much. 1/2" inch compression fittings tend to have less sharp edges so better. Use the washer as supplied with the flexi - rubber or fibre (I prefer rubber). Do not use PTFE.
