What lengths do the flexible compression pipes come in.
I need to connect a toilet to the feed and the flexible pipe I have is 300mm which is a bit long.
Can I get anything smaller? I had a look on screwfix site but couldn't find anything...
JG do a pushfit 150mm tap connector. Not a lot of 150mm sizes and mostly online. Need to be careful that if on the mains water supply that it is WRAS approved.
