Flexible type to extend 3/4" to fit into top of toilet tank now
30 Mar 2010
Rhondda Cynon Taff
Currently seems to be 15mm pipe isoltaion valve conntedted directely to toilet inlet. Assume this is 3/4" screw thread.
Anyway, new toilet is side entry only. What bests approach here? Can I even buy a 3/4" extension like this?
Or cut off the isolation valve and buy a 15mm pushfit to 3/5" screw flexible?
It'll be 1/2", flexi can be used but copper tube is preferable. If using push fit you must cut the tube with a tube cutter, jagged edges left by use of a hacksaw will shred the O ring in a push fit fitting and cause a leak.
To be honest I must buy a new cistern. £35 screwfix for bottom entry concealed one. A lot less hassle I think....
Probably should have checked before I bought the one I've got (from Better Bathrooms).
