Flexis tap connectors for baths
9 Aug 2009
Blackpool
What a people's thoughts on this? Flexis can rust and corroded and then blown under a bath you'd never see the condition of the flexis...
My thought is you didn’t finish and there was no question? Just do it in copper.
Not if the flexi's installed are WRAS approved and fitted properly. ALL WRAS approved flexi's are stainless steel braid, that is rust resistant and nickel brass ends which should not corrode. If they and the bath are fitted properly too then there will be no water/moisture in there to affect them.
The flexi's that corrode are cheap imported mild steel braided crap that should never be used.
