An inconvenience only noticed since having double glazing fitted.
We may have a 'cluster fly' problem or be providing shelter for flies in general !
Have noticed, with cooler nights, several flies gathering above the opening lights in the hinge recess. Here is the rub .. even with window closed !!
The seals are ok and tested with paper strip .. the trapped paper is seized when opening light closed.
Have observed the odd fly entering the 'frame' via the full length drain slot to plastic cill .... In my previous property the frame drains were capped holes along lower bar to cill.
Anyone had this problem at all ? Any prevention ideas ?
Edit :- No ideas at all ??
P
P
