hi all,
thinking of buying a house who's roof has been described as being rather flimsy - I quote:
"The roof structure is rather flimsy with 75 x 50mm common rafters and purlins to the main roof, 100 x 50mm ceiling joists and only one strut to each purlin together with support in the party walls. This results in a fair amount of deflection. There is no interim support for the ceiling joists and therefore they deflect also and should not be used to support storage of any significant weight...The back addition roof is even more flimsy with 75 x 50mm rafters, but only 50mm square ceiling joists. "
It's a vitorian terrace with synthetic slates...HELP! I know not enough...
thank you!
HMMM perhaps I put this in the wrong section - should be under timber bit..
thank you!
