- Joined
- 6 Jun 2024
- Messages
- 35
- Reaction score
- 7
- Country
Hello all.
When I use any of my cold water taps in the house, the part1 float valve in my cistern dribbles a little more water then stops, its as if when a tap comes on, the water in the pipe to the cistern drops back then pushes again forcing a little more water out. It stops doing it eventually, until the loo is flushed then the process starts again. I'm a little worried that this will reduce the life of the valve. Would a check valve before the float valve stop this by not allowing the water to run backwards down the pipe?
