floating floor joist advice/ventilation issues
Dann09,
You've got me worried. It's not that serious, this floor is above the cellar. Half of the cellar is accessible for storage,the other half is separated by a bearer wall and has been filled with rubble etc. There is ventilation but because there was so much stuff dumped that I believe it was affecting the air circulation and that is why the joists have rotted. The joist ends will be cut but I will be using a 2 metre piece of timber and use coach bolts to attach to the existing joist. This two metre is long enough for one end to rest on the bearer wall . The clay pipe is bone dry, the solum can be scraped out, what can I do to stabilise it? I must have removed over 50 rubble bags worth of material so that airflow would be improved.
