Flood light staying on
  • Thread starter Thread starter imamartian
  • Start date Start date
I
imamartian
Hi
I have a flood light that tonight has decided just to stay on ! it's on a PIR, and a switch in the hall... the PIR seems to have no effect, nor does the switch !! any ideas as to the root of this? should worry going to bed?
if the switch does nothing then either its the wrong switch or the contacts have welded together
More likely that the switch is an override wired between live in and live out on the PIR. I'd put money on a faulty PIR, not worth fixing, you need a new floodlight. Don't buy a cheap one, I fitted a couple of £5 jobbies before and they didn't even make it a year befre failing in the same manner.
thanks gents
It is one of those flood/pir all-in-one units.
And i think you're right about the switch, it is an override for the PIR - there is a switch in the loft labelled as an isolater for the light itself.
It did go off after about an hour (should be set to about one minute), but i think i'll look into replacing it.
