Depends on where the water is coming from and what you have in place for your ground water drainage.
Do you have gutters (or rainwater gulleys) that are overflowing. If so, clear them.
Is the water running in from the rest of the garden. If so, you could try installing a french drain on the house side, with a pipe leading the water away to a soakaway.
If you have a solid base to the patio you could install a gulley at the low end, and lead this off to, either your existing groundwater drainage system (BCO liaison required) or a soakaway (dependant on local geology).
If the water is coming off the rest of the garden, you may be able to construct a retaining wall, with a vertical DPM (on the garden side), this would then be back filled with pea shingle and possibly have a pipe leading away to a soakaway.
There are so many possibilities (most of them hard work), depends on you local geology, but providing adequate drainage is the key. Attempting to simply block the waters ingress will be futile.
If you can give us a more detailed description of the patio, we may be able to help. Is there a retaining wall, (if so how tall). Does the rest of the garden slope down to the patio (if so, what sort of slope). What is the patio construction, (is it bedded on concrete or sand).
