I have installed a new suspended floor in our extension and it has worked a treat 8x2's with a large air gap underneath to keep things dry.
I have hit a stumbling block in the new utility room. This was originally a garage. I had the original slab broken out and installed a vapour membrane 100mm insulation and 100mm slab. I then decided to use a bit of the garage to form a utility room. The slab sits 6" below the top of the joists. As this is an insulated slab below with damp membrane can I sit 4x2's flat as bearers to give some air flow and then 4x2's on top foowed by the deck? Building Control will not see this and I know its not perfect but given it is a small room would it work.
The room is 1800 wide so if I sat 3 bearers down the max span of the 4x2 would be 900.
