I had concrete and insulation put under my ground floor due to water rising from below early this year. The entire ground floor two rooms under floor was completely dug up and removed.
The contractor put in some kind of red crushed material, followed by thick plastic sheeting, concrete and then two types of insulation, thick blocks of something and a foam type underlay for the laminate. Following this, a new and expensive wood-type laminate floor was put over the top.
Unfortunately, the contractor failed to have the concrete reach far enough across at one end of the room. I repeatedly pointed this out but he insisted all would be well when the new skirting was put in. This was absolutely untrue. Now there are huge gaps at the junction of floor and wall, which you can put your hand in. There is also a big gap under the skirting. The draught is horrendous.
I've tried repeatedly to contact the contractor over more than six months but he ignores me. He also did not provide the 25 - year certificate he promised.
Now it looks as though I need to fix this myself. I'd appreciate any ideas or suggestions. The previous job was £11,000 so I don't have more money to throw at this. At the same time, my new fuel bills are to be more than double those of the previous year. This means that I have to do the repair myself. Five foot female, no longer young. What a joke.
I'm thinking to remove the skirting and put something in the gaps, but what? I'd rather not mess with foam, which someone suggested, and hoping for some other solution. I can mix concrete or something of that kind. Is that the best thing to do? Obviously, I can't remove the new laminate so this has to happen without damaging it. When I replace the skirting, what should I use to plug the gaps underneath?
Thanks for reading, I appreciate your time.
